Reactivate my BUD....suggestions requested..
hhummer
6
Midwest
My 10' Motorola Mesh dish, installed in the early 90's, has been unused since the receiver failed years ago. I switched to DSS, but with HD, would like to get the BUD going again before winter. Due to the time that has passed, I would want to upgrade everything except the dish and ribbon cable that is in PVC. The arm has seized, so that would need to be replaced, too. The receiver was C-band and early Ku-band, but that should all be replaced. Having been out of the loop in recent years, I would appreciate a recommendation on the better replacement equipment that I should consider.
Thanks!!
If you already have a c/ku feedhorn and lnbs, just grab a 4dtv dsr 922 with maybe a HDD 200 for HD if you wish and a Venture 24" arm, if you have any issues replace the lnb's to better ones, though if you only have a C-band feed then upgrading to a c/ku feed and lnb's would be well worth it.
Pansat 2700 & moving a 5' mesh
Dropping C-Band signal
