I'm thinking about adding another dual tuner to my system. If you look @ my signature, you'll see what equipment I currently have.
I currently have 2 cables run from my switch to my 622. My question to you is; should I upgrade to DPP equipment & lose the 2nd cable to my current 622 & use a splitter at that and a splitter @ the new one, or should I purchase another DP34 & cascade it to my current one & run a 2nd line to the room I wish to upgrade? The room I'm looking to upgrade is easy enough to get a 2nd line to, however, back when I built the house, the RG6 I used was the standard 2260(?)MHz & it's not all that easy to replace the main run w/ the 3000MHz that seems to be recommended for the DPP44, power inserter, and newer LNB's...
Has anyone cascaded the DP34's, if so, any problems doing that?
Thanks for reading!
Thanks for reading!
