Question about multiswitches
Doomster
13
I'm specifically referring to this one:
http://www.smarthome.com/77958t.html
It's a 5 x 8 switch made by Terk. There are 5 inputs. 4 from the satellite, 1 from antenna.
I currently use two 3x4 Terk switches. I have two cables coming out of the DirecTV LNB. They become inputs for the Terk switch.
I want to get a few more DirecTivo boxes for my other rooms. I need to split the signal more.
My question is, if I get the 5x8 Terk switch in question, how will it work when I only have 2 inputs from the satellite? If I have only two inputs, will the Switch split then to 8 outputs? Or will 4 output jacks be non-operational?
Doomster
it should work
otherwise there are 3x8 multiswitches on EBay and other areas
Heck, there is even 2x16 multiswitches :)
Sounds like you have a 18" dish if you only have 2 satellite feeds.
The 5x8 will work but a 3x8 will do the same thing and will be cheaper. On the 5x8 you will use the satellite A inputs, satA 13v and satA 18v NOT 22k.
AT9 Manual
Two Tivo Issues.
