DM04/QQbox DiSeqC output - the hard truth.![]()
The problem has been resolved. I will release the driver fix soon.
Driver fix to add Diseqc functionality to the QQbox?
I have updated my driver, but the QQBox is still troublesome. However, the DM04 works fine.
The QQBox appears to suffer a design issue, with the LNB voltage which appears to have a great deal of switching noise coming from the DC-DC converter close to the tuner. This may trigger the LNB to the high band and disrupt DiSeqC commands. However, if QQBox sends command under windows to a switch it should be okay.
The layout of DM04 is different in that the DC-DC converter is well away from the tuner.
Yes, I have ordered the part. This is the primary reason for DOA QQBoxes particularly with Windows where tuning starts in the low band.
However, I have managed to drive the rotor successfully on the end of a switch. Interestingly, the rotor gives more trouble being driven of LNB 1 than any other port.
The timing for DiSeqC commands is critical with the Linux STV0288 module. It needs some work done on it to bring it up to level 2.x. There is also no error checking. I am currently working on this.
I've noticed a strange behavior of the QQ-box. There is great difference in signal/quality, when powering the LNB through the Sharp tuner, and powering it externally, using loop-out of my dreambox (using decoupling capacitor). On a transponder showing about 30% of quality (using windows driver), when powering the LNB externally I have 80-90% of quality! After i suspected a noisy DC/DC of the QQ-box, I've tried to power LNB bypassing the Sharp tuner. I desoldered the Schottky diode before the tuner and connected it externally through a RF decoupling coil and a decoupling capacitor to power the LNB. For my surprise the quality rose from about 30% to about 70%!![]()
The values of the capacitor and the inductor are not critical. In my case the capacitor is 220nF and the inductor have 7 turns with inner diameter of 3mm. I know that this is not the right way - it was just an experiment showing where the problem is.
If i put the coil in series with D105, there is no improvement. So I suspect a problem with the inner layout of the small sized Sharp tuner.
That is good information.
Even though the tuner is a "Sharp" product, it is made in China not Japan, quality suffers.
I noticed that without the case there are fewer problems, possibly the L101 hash getting into the tuner. Have you tried slipping the case over your modified board, leaving the end open?
Since i have replaced the L101 with shielded one, I can see no difference with or without the case. Before the replacement some programs from specific transponders were impossible to watch with the case on.
