Well, I don't know if you can call this progress or not but under Ubuntu Linux 12.04LTS, I obtained the local network address of my Amiko Mini HD SE (10.0.0.5:2871 for Ali Media Server) using GUPnP Universal Control Point.By chance, would that include the Amiko HDSE? Can i stream to VLC with it? I didn't think so being we are all trying to run big2small Android on a windows system.
I then entered that under Open Network Stream in VLC and was able to capture this video. It's not a stream from one of my channels, more like a logo or something, but it did come from the Amiko Mini HD SE. It's in a ZIP file since uploading a video did not appear to be an option.![]()
I tried several ways as well and that is the only one that worked.I couldn't even get that far. I put the IP address of my Amiko into VLC with no port specification, with the port 2871 and with the ip : port/satip.xml and vlc said it could not open up a stream on all three of those attempts??
This is what I get in Firefox:I'd be interested in opening that xml text file . May hold a clue as to where the program stream is.
Only thing I did was go into the Applications menu and make sure Big2Small was set to on.Do you have to enable streaming from the STB????
i have installed in a virtual enviroment android 4.3 for x86 and installed the amiko app but cant test if you can stream to it that way as i dont have a wifi dongle fot the amiko minihd seDidn't know where to put this question, but have been thinking about it for some time.
Has anyone emulated android in windoze, or Linux, and installed the amiko app with success???
Any way for you to run an Ethernet cable directly to it?as i dont have a wifi dongle fot the amiko minihd se
Did you use Andy? or what to get the Android Emulator. I tried Andy, and I couldn't get Android to work. I just kept seeing a black page with the power symbol in the top right...i have installed in a virtual enviroment android 4.3 for x86 and installed the amiko app but cant test if you can stream to it that way as i dont have a wifi dongle fot the amiko minihd se
I have not tried this App but it looks like it should do what is needed. Install on the Android client device that is running big2small. Capture packets, change channels several times and it should record how ALi is streaming the live satellite. https://play.google.com/store/apps/details?id=jp.co.taosoftware.android.packetcapture Take the output file to the computer and go through it with Wireshark.
You also might want to use the Amiko Android App as client instead of big2small. It has some improvements. https://play.google.com/store/apps/details?id=com.amikostb.alistream
The Amiko App is in our A3 F-Droid Appstore and can be installed from there on A3's. I still have not tested this route here but at least in theory it should work.
