Problem with 811 remote controlling other 811 receiver in another room
sjones
32
I just had dish installed and the only problem i've run across so far is that the remote in one room is controlling the the other 811 receiver which is located in a completely different room. They are nowhere near each other and the rooms are not close to each other. Any way to set these things up to use different frequencies so one remote doesn't control the other receiver and vice versa? I already tried removing the small antenna hookup on the back but then the receiver doesn't respond to remote commands at all.
You need to change the remote address.
Pick one receiver that you want to change the address on.
Turn the other receiver not being changed OFF.
On the receiver you are changing, press SYS INFO.
On the remote hold the SAT buttton untill all mode lights light up, then release
Enter a random number from 2-11
Press #
Press record.
The remote address should change on the receiver
This is a common problem with installs that installers are suppossed to change during the install but they dont. I had the same problem
