cr0mag said:I'm going to go home tonight and take a good look at my signal strengths.... I'm still blown away by the fact that at .5 degrees seperation a LNB can still get enough of a signal. In my infantry days we learned just how far off course you can walk by being 1-10 degrees off your azimuth when you are looking at 1-5 miles.
Now, my trig is very rusty but I think (think, mind you) that a .05 degree of seperation at 22,500 miles would net you a difference of 1,125 miles on the ground. Isn't that a big reach for small dishes and LNB's?
dfergie said:both the D* and E* "locals" PQ sucks
The Local "digital" cable's locals Pq is about on par with The Charlie Chats Pq ( terrible) and Hbo ....charper1 said:I still think most affiliates are in bed with their local cable companies thanks to the NAB, and want you to leave DBS. They hate DBS achieving a 100% level playing field.
LonghornXP said:On national coverage its not enough to screw much up. Its still going down and those extra miles are most likely reducing ocean coverage which means nothing. As long as the signal can hit the dish the dish will bounce it onto the LNB at the right stop. If the East and West Coast can both pickup a signal at 101 and 119 I don't see a problem with this. Again its not like the signal has the hit the LNB right on it only has to hit the dish which it will and the dish itself is curved to reflect the signal onto the proper LNB depending on the angle the beam hits the dish. That change of angle won't be enough to throw it off. The only reason the new dish will have 5LNBs is not so much because of the new orbital slots but because the signals will be KA and its best to have a seperate LNB for that. If Spaceway 1 was KU they most likely could use the current dishes in the market today.
So it is safe to assume (ass-u-me) that DirecTv 8 is in fact hot, and based upon your post above even 2.5 degrees seperation is fine since the beam is so wide anyway ... is this correct?LonghornXP said:I can say that stuff is being moved around but from and where to I can't say. From what I've been told is that the new encoders are both MPEG2 and MPEG4 SD and HD encoders. So these encoders will be used for all current D* offerings both now and into the future and one benefit of them at least for current national and LIL SD offerings is that they can have much better error handling which results in an increase in bandwidth because they can use more bandwidth on each xponder for actual bits instead of error correction. Just that little bit of difference will increase picture quality across the board on the SD side. Also it seems that some if not all of the HD channels will be moved onto D* 8 because it has higher power on the KU side of things so that combined with the new encoders would both increase picture quality and bandwidth. Now how much of an increase is unknown at this time. What is known is that this is more of a testing aspect and also is needed to prepare for upcoming LIL and national HD offerings.
Based upon the 1B debt they just secured it is not like they cannot afford morecr0mag said:GOOD question Rad.... Although I would have thought that E* would get first dibs on anything in the V* yardsale.
slacker9876 said:So it is safe to assume (ass-u-me) that DirecTv 8 is in fact hot, and based upon your post above even 2.5 degrees seperation is fine since the beam is so wide anyway ... is this correct?
Well speak of the Devil ... Lyngsat is listening too!!! they just updated and SpaceWay 1 is now at 109.70!!!! It would be nice to see the actual for DirecTV 8 since their last update for this bird was on Thursday (050623). Okay this is weird the date still shows data from 6.24.05 ... but the position is way updated ... I know I have not lost it (my mind) yet.slacker9876 said:You know from the tracker page it shows the following ... and this is almost "live" data
DirecTV 1: 101.11
DirecTV 1R: 101.81
DirecTV 2: 100.75
DirecTV 4: 101.06
DirecTV 8: 103.42
SpaceWay1: 107.19 (not in geostationary orbit)
I could be wrong but 2.5 degrees out of position would indicate that some of us are hallucinating unless they moved programming off to the 110 & 119 slots. Which does also seem logical.
I am at the office right now but I'll have to check this out tonight. It would go a long way to explain how they lit up the Active services too.
Now it is at 109.98 .... it is listed as not being in geostationary orbit ... what it is slot?beast37799 said:it seems that spaceway is moving the wrong way
