Position Setup and Signal Finder Menus.
rikoski
16
Indiana Dunes
I'm working with an Edision OSMio 4k; 2020-04-20. Enigma 2020-04-09. I would like to know how to use the Position Setup and Signal Finder menus in the Setup Screen. Specifically: Tune, Autofocus, Calibrate, Calculate and Go To. What are these for and how would I use them? Thanks.
Tune will bring you to a menu where you can input a satellite and select a transponder from a built-in list or you can enter your own parameters (manual settings). Autofocus is suppose to peak your aiming but sometimes it bombs out with messages about sync or unable to determine east or west "limit" (not the same as setting your east or west limit). I'm not sure about Calibrate. Calculate is suppose to reposition all programmed satellite positions after readjusting the current satellite position. Goto 0 is for HH mounts. Goto X or Goto Position sends the dish to the programmed position. I'm not sure of what Allocate does. I suppose an online help feature should be added to the firmware?
Has anyone try Amiko Viper combo 4K E-2 reciever?
Are these T2-MI?
