I've been using a WSI DMX-521 LNBF for quite a while and I've had no complaints about it, but when I saw an Invacom SNH-031 on eBay for less than the retail price, I jumped at the chance to try what's supposed to be one of the best LNBFs available. After all, everybody says that the specs on the DMX models aren't accurate, whereas Invacom's are, so I expected a big increase in signal quality on problematic transponders.
I installed it tonight and tested it first on SES-1, since that's where my dish happened to be pointing. I had had a quality reading of 71 on my Openbox on the BVN transponder with the DMX-522. With the Invacom, I got a quality reading only in the 50s. I scanned the satellite and got all the channels I expected to, but all at lower quality. So, I moved over to Galaxy 19, which isn't as strong as SES-1. I only got a few transponders on that satellite instead of the 20-some I usually get. So, that ruled out weather or trees or anything blocking my line of site.
I tried moving the LNBF forward and backward in the holder, but I only got a slight change in signal quality no matter where I moved it, and mostly downward rather than upward.
I've read about Invacom's LNBFs causing feed arms to sag because of their thick metal casings, but my dish is a GeoSatPro 90cm with the feed support arms installed, so I don't think the arm is sagging. I thought about the possibility that the whole dish could be sagging on the pole, but I don't think that that's happening to any noticeable degree, because I used to have a Dish Network LNBF mounted alongside my FTA one and that's a fairly heavy unit in its own right, plus my dish moves further than that when the wind blows without the signal going down that much.
So, do you think I have a bad LNBF? It was supposed to be new, but it appears to have been used because there are a few dirt spots on it. I've heard about Invacom clones, but I don't think this is one because it has a hologram sticker on it -- although there was no hologram sticker on the box.
