I have a Dish 500 with a Dish Pro Quad LNBF, which means I can get 110W and 119W with the same dish. From my research it appears if I get the dish pointed properly at 119 I will also have it properly aimed for 110. Is this right?
When they are both received through the same dish, you have one setting. Go to dishpointer.com at the top of the page, type in your address, click on multi lnb, selectect 110/119 satellite and it will give you the correct setting.You mean if the settings for 119 are correct, right? 110 and 119 have different settings.
