Hang with me. Just to clarify.
If I go out tomorrow, I should first reset the receiver, then enter in my latitude and longitude, set my correct LNBF settings, pick SBS6 out of the satellite list, find an active transponder (which seems to be hard for SBS6 right now), go into the USALS menu, let it motor to the position of SBS6, fine tune after that for SBS6, and then reset it back to zero, which should disrupt my tuned signal for SBS6? My true south satellite is at 193.2 degrees on the compass (74 degreeswest) according to geosatfinder. Where would the motor at the zero position be pointing to be at true south? I was under the impression that even at the zero position, I should be pointed at 193.2 degrees on the compass.
MALONE, NY 12953
United States
Latitude: 44.837 N
Longitude: 74.257 W
Using those coordinates, how would I go about pointing my motor and dish in the direction of true south using a compass, so it would need to move to be pointing at my true south satellite?
Essentially I know that my true south satellite isn't exactly true south now, but I can't understand how I would go about finding out where my real true south is, not just my true south satellite.
I hope you can understand what I'm actually trying to get at here. It's late, but I'm hoping that this may be the problem that I'm running into with tracking the rest of the satellites.
Thanks for helping me out with this, and having the patience to deal with someone who is apparently extremely dense.
Edit: Wow, either I'm tired and just don't know it, or I'm incredibly stupid. But essentially I just take 180 degrees on the compass and add my magnetic devation from it to find the real true south? It should be real close, but not exactly the position of my true south satellite. Am I getting warmer?
To give an idea of what he's talking about, I happen to be at 83.9w, if I use AMC9 at 83.0w for my TS satellite, I would first let the receiver use the USALS and move the dish to AMC9, then I would fine tune the dish for AMC9 while it's pointed at AMC9. I would not fine tune the dish to AMC9 while in "0" position under any circumstances, because then the motor would not be pointing to True South, it would be pointing to AMC9. It then would not track correctly across the arc. If you allow the receiver to move to the position of your TS satellite, and then fine tune it to pick it up, then if you go back to "0", the motor should be pointed to True South and not to your TS satellite. Now it is possible for your TS satellite to actually be True South of you, but most people don't fall under those circumstances, they're just not that lucky. The bottom line is, the motor has to be pointed True South, regardless of where your TS satellite is located. I could have used AMC9 @ 83.0w or AMC2 @ 85.0w for my TS satellite, my location is about half way between the 2 of them, but I actually used AMC3 @ 87.0w, because it had several TP's to choose from, to make it easier to find. I used the USALS and moved to AMC3 and then tuned it in. Good Luck on finding your sweet spot!
Al
