I had the Dish installed last week, and the picture quality isn't too impressive. I went from digital cable, and it's a huge step down. It's about on par with standard cable, maybe a little less. Dish claims I should be getting quality about the same level as the digital cable. They did run into my existing cable wiring, and the Dish folks says that could be why, so I replaced it with brand new RG6 cable that was pre-made, with the connectors, so there shouldn't be a grounding issue. It's hard to compare the picture - it's not very sharp, and the colors look odd sometimes. They best I can compare it to is watching a decent quality AVI or DIVX on a pc. Also, once or twice the sound (speaking) got out of sync with the picture.
I've never seen another Dish picture, so I don't have anything to compare it to, but I thought it was supposed to be better than it is. Do I just need to get used to it?
Also, DISH said I have 90 days after the install if something is wrong, but I need to go thru my dealer for that. (who just called DISH and has them come install) Should I have them come back and check the setup? Will they charge me if it's in the first 90 days? Is there anything I can do on my end? I've got it going to 2 tv's, both look about the same.
Also, I have superdish, which the DISH folks say is supposed to use 121 I think, but I get half signal on that, But a full signal on 119, which is what the installer kept pointing out. Not sure if this affects anything or not.
