I originally visited this subject about 8 months ago, but need to revisit. For a while, I went away from PFsense because the beta was jacked, but now that v2 Release Candidates are out it is much more stable. Except of course when you want to use the sling adapter.
I have tried a whole ton of things as far as internal and external ports go, but every time I try to connect either via a remote PC or my Droix X, it says that Sling is not available. I recently upgraded to Docsis 3 to get the 5mbps up load, but when you cant even connect, it does you no good.
So, my question is, is there anyone out there using the Pfsense for their firewall and able to access the sling adapter? I do see my firewall blocking some traffic when I try to connect to the sling and it always appears to be a random port, so maybe that is the issue. I know when I used smoothwall as the firewall it worked, however, the issues there with snort made me stop wanting to use it, so instead I went to Pfsense, but if Sling doesnt work, I may have to switch to something else.
If there is anyone out there with pfsense and their sling adapter does work, I would really like to hear about their configuration. Thanks.
