Need help. I'm trying to send 922 sat signal via composite a/v and ota antenna via coax thru an rf modulator and then to 2 other tvs via the rf modulators coax output. The ota signal is strong to all tvs until i connect the yellow composite video cable then signal degrades to the point that I lose some local channels. I have used this method with good results in the past. Interference just started about 2 weeks ago. D*sh tech insists its a grounding problem but I've checked ground and connections and all seem good. Replaced modulator but no help. Replaced cables but no help. Don't know what else to try. Any chance that the composite video output on the 922
has gone bad. I do live near the center of the east coast earthquake from 3 weeks ago. Thanks in advance for any thoughts.
