Thanks 907tech;
The current attic antenna (terk 55) was installed by a company that installs security systems/satellite and phone cables 18 years ago when the house was under construction. The ant. coax ran to the basement, then split with a 4-way splitter and 4 coax cables were installed into different rooms behind dry walls along satellite cables. So, we had two cables coming from walls behind tvs. We simply changed the input on tv when we watched local networks. When Dish offered locals, we stopped using the antenna. Not all reception was perfect. But, we accepted it.
I want to avoid installing antenna on the roof for several reasons. The roof is very high, hate to drill holes for leakage problems, maintenance, etc. I am also acrophobic, afraid of heights!
So, I have decided to replace the current antenna with a newer one under the roof. A friend here suggested a brand.
I ordered it on ebay. (less than $20 with tax and free S&H). Here's the details:
Features:
1. Made of high quality plastic & aluminum material, durable and practical in daily use
2. With the light weight and compact design, it is easy for you to operate
3. It supports 360°rotation which will provide agood signal
4. With low power consumption and environment friendly design, it is worth to buy it
5. Rotation speed up to 2-4 rounds/min
6. Remote controlled distance is less than or equal to 5m
Specifications:
1. Frequency: 45-860 MHz
2. Gain: 22-38dB
3. Rotation: 360°
4. Channel: VHF1-12 UHF21-69
5. Impedance: 75 Ω
6. Power: 3W
7. Power Supply: AC110V
8. Rotation Speed: 2-4 rounds/min
9. Remote ControlledDistance: ≤5m
10. Standing Wave Radio: ≤1.5
11. Model: TA-851B
12. Color: Silver
13. Weight: 38.80oz / 1100g
14. Material: Plastic & Aluminum
15. Brand: Leadzm
I don't know much about all the details, to be honest. Just hoping that it will work. I am not expecting dozens of free channels. If I get couple, I will be happy.
