Iceberg said:you mean MeTV.![]()
yes I also forgot out here we get the remap from the ktsc 45. ksax is our primary ota abc.
which stinks because no abc in hd
Iceberg said:KSAX isnt in HD?
dang...
side note...I noticed your loc says Willmar. Are you able to pick up the low powered stations (from UHF TV Inc) there?
Our Local KSCW station 033-1 has always had the correct guide info until a few weeks ago. At that time a new channel 031-1 was added, a local Univision channel. Ever since then the CW channel has had the Univision guide info. Really screws up my timers for Supernatural and Smallville. Emailed Dish and I got the standard reboot recommendations, when that didn't work they had me send all my receiver info to them and they said they would forward it to the techs, no fix yet.![]()
Hehe, sent almost a year ago....11/3/10
How can we get the program guide data for some local sub-channels corrected ? Dish does carry the primary channel and in these cases,
people with 622, 722, 722k and other receivers using OTA input via antenna get guide data for sub-channels of the channels carried by
Dish. I have two issues:
1) WPTD (PBS) has (5) channels. I get guide data for ALL of the channels except for 16.2. It reads "Digital Service". I was in contact
with an engineer at WPTD who in turn contacted people at Dish to fix/update the guide data. They had re-arranged their channels and the
Dish guide was out-of-date. It got partially fixed but this 16.2 information then got broken in the process.
2) WKEF (ABC) recently (2-3 weeks ago) added "Cool TV" to their 22.2 sub-channel. It also reads "Digital Service".
They CALLED Dish Network (and yes, they do have a 'special' phone number) to get this sorted out. Look where we still are today...7/9/09
Good morning Mr Stone
Could you help with a Dish Network related problem ?
When WPTD (and WPTO) switched off analog, you also switched your sub-channels around. 16(14)-5 became 16(14)-1. Not sure if anything else changed based on the messed-up guide I currently receive but I do know that my daughter has tried to record "Curious George" at least twice off of 16-2 (??) but ends up with a different program.
Dish or whoever they get their guide data from hasn't updated things on their end yet. As I understand it, Dish's receivers that are also OTA-capable do not use the PSIP data sent by stations either. From a customer's standpoint, their support people simply won't listen when this is attempted to be explained. Any errors in the guide data will be blamed on the station. I haven't hooked up my old digital set-top to confirm this but I presume you have correct guide data for all of the sub-channels.
My understanding of the guide data is that Dish's receivers do "read" the "TSID" and then cross-reference or map that to guide data they purchase, which is in turn displayed on our receivers. Does that make any sense to you ? I could be completely wrong, of course.
Anyway, I presume that stations have more *direct* access to the engineering side at Dish Network and can get things done quicker and maybe easier. Can you help ?
In what market does Dish carry ANY sub-channels ? None that I know of. In the case of a local station that carries, say "NBC" on -1 and "WB" on -2, that doesn't count as they are unique networks....BUT the PBS in this market has multi channels and only ONE, the main, is carried on DISH, but DISH has program data for ALL of their sub channels. Dish must be doing something.
In instances of channels reading "Digital Service" for stations that Dish does carry -- the whole point of this thread -- there is a mis-match of the TSIDs. The station is transmitting one TSID and Dish is looking for a different one. When they don't get a match, they default to "Digital Service". For some of us, this has been going on for months if not years. Some argue "the station is sending the wrong data" and that they should fix it.
Let me be more specific: IF the sub-channel is a stand-alone network and Dish carries it, it's a different scenario. My local PBS has (5) total channels. Dish only carries (1) (the -1). My local ABC is 22-1 and they have CoolTV on 22-2. Dish only carries the -1. My local CBS has the main channel, -1, and "Weather Now" on -2. Dish doesn't carry the -2.
No, no, no ... I'm not referring to guide data (yeah, I know, that's the topic of this thread but we went off-track slightlyI guess it depends on the market. Here in Minneapolis Dish carries subchannel info for a few channels...
WPTD has been messed up for years. I can only presume that Dish is looking for a different -- or WRONG -- TSID.Here is what doesnt make sense. According to another site DIsh shuld be providing the EPG for all the PBS in your market (assume Dayton). Here is the list for your market...
I've read this many, many times and don't doubt that it's true, but do you have a link to the actual FCC 'rule' ?I just do not know how the FCC allows this since they REQUIRE it for digital receivers.
