OTA Antenna Help
baltimoreravens
6
We have Dish Network at our house in 19930. We have one HDTV and two normal TV's The local channels in Salisbury, Md. would not grant a waiver so to get our beloved Ravens games I need an OTA. Channels are only UHF. I would like a combo unit that would connect to the dish and use the same cable. Please advise which antenna you would purchase for this dilemma. The site says we need a violet antenna as we are 32 miles from the transmitter. There is no elavation in Delaware. No real obstructions either. Thanks for any and all help.
There are lots of threads on this already. What I use is the Channel Master CM-4221, it is a UHF bow-tie antenna, rated to 45 miles. I also tried the CM-4228, rated to 60 miles, but having too much gain can be a problem. I took the 4228 down and went back to the 4221. Rasie it above the roof-tops, and get it pointed in the right direction, and it will work great. Joe
Need help with OTA HDTV
Terk HDTVa (or HDTVi) antenna question
