I have done some searching for the answer to my question, but haven't had much luck. I am seriously considering upgrading to a hopper from my existing 722. I have had the 722 unit for a LONG time and have learned a lot over that time about the setup. In reviewing the diagrams from DISH on wiring for a hopper I see one diagram that uses both cables from the dish to a single node and another diagram that only uses one cable from the dish through the node as output (capping the second output and adding a "tap" before the splitter). Is there any particular advantage to the two in two out version? I currently have two cables running from my dish to a grounding block but only one of the cables is tapped to go to my 722 where it is split to both tuners. I should be able to use either scheme without running any additional cables. Just curious about any advantage.
I have a few other questions as well:
I notice the diagram for the hopper shows grounding of the node. Does this eliminate a need for the current grounding block? Do you have to have an installer do your hopper upgrade? When I got the current 722 the guy who came on site was clueless and I had to wait until he left to finish the install and set the unit up properly. (By the way, I know there are some excellent installers out there, I just happen to get a guy who had been with dish for about 3 days, and I was more frustrated with dish for putting him in that position than I was with the tech himself). I currently use the modulated output of the 722 to service numerous (6) other TV's around the house. The line out has a 10db signal boaster and I am able to mirror what is on the 722 to SD and older sets that are just there for casual viewing -- Master bath, workshop, laundry room, etc. It looks like I can use the component output of the hopper with a modulator to achieve the same results for my older sets. Am I correct?
I ran all new RG6 (swept to 3000) and Cat5e lines to virtually all room in my house when I had the opportunity due to replacement of two AC units. I believe I have all the necessary cables to make the install relatively easy.
I would be purchasing one hopper and two joeys for now, with a possibility of adding a third joey in the future as I renovate my basement and perhaps include a home theater in the update.
Any help, suggestions, etc would be appreciated. I have been a dish customer for a long time, starting out with what I think was called a 300 or a 510 and moving up from there. While I have been frustrated with DISH more than a few times, it still seem to far exceed anything else (Direct TV, etc, etc) out there today.
