So...
If I want my picture to shrink to 4X3 letterboxed with black bars all around, I need to mis-align my dish so the signal is marginal?
The problem is with either dish or the local. Just to clarify , I get a postage stamp picture on both my 4x3's and my 16x9's when I watch a show such as seinfeld on any receiver.
Just because your other locals are normal doesn't mean the problem is at the station. Dish has a receiver for every station in the market. Assuming you're watching an SD version of the station, Dish downconverts the signal. THAT'S where it sounds like the problem is. Comparing the same channel on cable vs. satellite shows the problem on Dish only, right? THAT points to Dish right there.I was also able to scan ch 55 in from cox cable and compare to the dish feed on the same TV, and the picture is normal not postage size like dish. I'm leaning towards the local channel being the problem, after all it's the CW network maybe they don't have enough money for the proper equipment. All my other locals are normal.
It has to do with low signal strength or poor signal quality.
The shrunken picture is a type of scalability that is built into the MPEG forward error correction. Your television receivers AND your Dish receivers (Directv, digital cable) everything using MPEG 2/4 has scalability, built right in.
When you have less than the minimum of 70 on a standard digital signal quality meter (everyone's meter except the new improved dish signal meter where there is no longer any standard...), there is built-in or rather "written" in, coding that allows for the decoding of a weaker, or compromised signal. It is called Scalable Video Coding extension, and has been a part of HDTV since at least 2005.
One of the types of scalability that is available to use, is spatial scalability. This scalability says, "Since the signal is poor and there is not enough data to produce the full size picture at the proper resolution, then I'll display the proper quality, or resolution, at a reduced size."
These are three types of scalability. They are temporal, spatial, and fidelity scaling options. Broadcasters and TV manufacturers use all three of these handy, low-signal digital tricks.
Spatial scalability is what you are witnessing on your TV. Here the quality remains but the size of the picture decreases. Dish does NOT use this type of scaling because it too easily leads to the truth of the picture/signal relationship.
Fidelity scalability is scaling that reduces the quality of the picture (grainy, blurry) but maintains size. Since most people don't see this difference, and the perpetuation of the "all-or-nothing LIE" says that signal is NEVER the problem, this type of scaling is acceptable to Dish.
Temporal scalability refers to time scalability and accounts for a good portion of the audio sync problems that are being reported. Since these also have a reputation of being blamed on software issues and such, so this scaling is also acceptable.
The rest of the story is on WOWVision and the HDTV Picture Quality blog.
The link to the technical info regarding SVC scaling follows:
http://ip.hhi.de/imagecom_G1/assets/pdfs/Overview_SVC_IEEE07.pdf
BS. Definitions of the terms you are using.
* Temporal (frame rate) scalability: the motion compensation dependencies are structured so that complete pictures (i.e. their associated packets) can be dropped from the bitstream. (It is not so that packets CAN be dropped from the bitstream, but instead, it is for when there have been packets dropped before decoding. It enables a lower quality reconstruction which is especially noticable during fast motion sequences.). (Temporal scalability is already enabled by H.264/MPEG-4 AVC. SVC has only provided supplemental enhancement information to improve its usage.) (Temporal scalability is the primary cause of motion blur in low signal systems. Motion blur arises from poor signal quality, but calibration should be considered in the equation to a lesser extent.)
* Spatial (picture size) scalability: video is coded at multiple spatial resolutions. (Correct.) The data and decoded samples of lower resolutions can be used to predict data or samples of higher resolutions (Correct, but when slow data, poor signal quality, or burst noise occurs, the amount of data available can be less than is required for the reconstruction of the higher resolution picture at the desired size. With spatial scaling, the quality remains high, but it has only enough information to produce the higher quality in a smaller size, or using a smaller number of pixels.) in order to reduce the bit rate to code the higher resolutions.
* SNR/Quality/Fidelity scalability: video is coded at a single spatial resolution but at different qualities. (Correct. The data and decoded samples of lower qualities are used when there is too much corrupted data, as in a low signal quality situation. The result is a picture of the correct size, but it has less detail. This is what is refered to as the "blurry" or "blotchy" picture that is regularly reported by users.) The data and decoded samples of lower qualities can be used to predict data or samples of higher qualities in order to reduce the bit rate to code the higher qualities. (Lesser quality data is used in the presence of a lack of high quality data.)
* Combined scalability: a combination of the 3 scalability modalities described above.
These are not related to retransmission by satellite. (They are related to They are related to the original source and what is done from:
* Streaming
* Conferencing
* Surveillance
* Broadcast
* Storage
E* takes these sources as given to them and just rebroadcast them after the satellite encoding process. (Just what I said. Dish received a compromised signal from the broadcaster and the SVC scaling gave them the required resolution in smaller size. They sent what they got. That is why none of the formating options would do anything to change the picture.) If signal level is too low they loose the source and call the provider. The do not change these qualities. ("They" do not have the ability to change these qualities. The decoders within digital receivers do this without any input other than the quality of the signal that they have to work with.) Signal level has little to do with any of these. (Signal level/quality/fidelity has EVERYTHING to do with these. Signal-to-noise ratio is still the measurement of signal quality/fidelity. Signal-to-noise ratio is analog at the antenna, and it is the quantity that gives BER. Bit error rate determines quality. Forward error correction is based on a minimum signal to achieve the Quasi Error Free point of operation. Quasi means "Fake, or copy". The quasi error free point of operation is 70 on all systems I've used including Dish Network...until recently...) It is either working, pixelating, or gone nothing else. (Incorrect. It takes only a little research to determine that this is not the case. A quote from an article regarding MPEG's Scalable Video Coding (SVC - previously known as Signal-to-noise Scalability or SNR scalability)
"In general, a video bit stream is called scalable when parts of
the stream can be removed in a way that the resulting substream
forms another valid bit stream for some target decoder, and the
substream represents the source content with a reconstruction
quality that is less than that of the complete original bit stream
but is high when considering the lower quantity of remaining
data."
and,
"SVC provides functionalities such as graceful
degradation in lossy transmission environments as well as bit
rate, format, and power adaptation."
How do I know these things I work for one of E*'s providers and if they loose the signal they call us almost instantly.
How do I know these things? I have no degrees. I have no formal training.
All right Jeff. I've been defending your position in at least two other threads. But I think you diagnosis is wrong on this particular problem, and the broadcast engineer (Sam Gordon?) is right. Some boob is incorrectly downconverting a 4:3 picture, either at the station or at Dish. When the culpable party notices his goof, he'll simply flip a switch somewhere and fix it. That is my prediction.The problem is spatial scaling that occurred at the point of Dish receiving the local broadcast. They aren't receiving enough signal from the broadcaster and their decoder scaled the picture.
Ignore hideafjeff, he's constantly spitting out his propaganda that you don't have a good HD picture unless you have maxed out your dish. But this by far my favorite! It just so happened to drop signal on the side bars of the screen causing them to go black. LOL!!! AMAZING!! Maybe it's because the guy has a square LNB and not a rectangular 16:9 LNB right?
It would seem so. He appears to be on a crusade. And while I think some ire is warranted, error compensation in poor signal conditions is a good thing not a bad thing.You guys are still entertaining deafjeff eh? He's fun....
jeff-
Want to actually TEST your theory instead of just trying to read white papers? Setup an OTA antenna, tuner, and TV. Tune in a local signal. Now, move the antenna AWAY from the transmit tower. Watch your signal level drop. Does the picture "SHRINK"?
I'm willing to bet as the signal level drops, first you'll see no change, then you'll see increased macroblocking/pixelization/freezes, then the "no signal".
Go ahead, try it. We'll wait.
All right Jeff. I've been defending your position in at least two other threads. (And I THANK YOU! I am sorry for this long overdue appreciation...I should read all the posts once in awhile.) But I think you diagnosis is wrong on this particular problem, and the broadcast engineer (Sam Gordon?) is right. (And I appreciate your opinion!) Some boob is incorrectly downconverting a 4:3 picture, either at the station or at Dish. When the culpable party notices his goof, he'll simply flip a switch somewhere and fix it. That is my prediction.
As for spatial scaling, I agree with you that it exists and it's visible, but it's not that visible! ("That" being to frame the entire picture in black.) It is exactly THAT VISIBLE. Spatial scaling that I have witness - and according to all I've read - does exactly "that". I do know the difference between a combination of letterbox and sidebars (which will respond to format buttons) and a solid black frame around the picture that doesn't respond to a format button. What I believe this refers to is one type of error compensation where the video is reproduced at a lower resolution than it started out, because not enough data made it through intact to reconstruct the original picture in all it's pristine digital high-res perfection. It should still display at the same total size on your screen (not picture-framed!), resulting in a transient blurriness as the scalers inside the receiver do their interpolative magic.
