Omegasat5700 Frozen
bowne
NY
Hi my receiver is stuck it wont turn off unless i hit the main switch on the back, and it doesn't send a signal at all to my tv, its displays the code F512 but i can't find if its an error code or not, anyone ever encounter this problem?
Never encountered that problem as I do not have a Omegasat 5700..Looking at its specs I would say it has done you a favor!
Take a look at a Linkbox,AZbox,MicroHD,..
As I repair some receivers, I believe your problem is power supply filter caps going/gone bad. Look at power supply board and check for bulging, rounded tops, not flat tops on the capacitors. Replace any that are rounded. drjohn
US Free to Air Satellite Viewers
pansat 9200 HD
