Didn't take long for a Charlie devote to come out - imagine that...
TNGTony said:
Where do you draw the line? Do you subscribe to every channel available on your system (I mean every one?) The answer is probably no. My question is Why not? Probably because at some point you said it costs too much. Your neighbor may not agree. So if your neighbor gets everything, why not you? Are you just being cheap?
We are talking ONE fricken channel here, NOT an entire range - I really don't understand what this has to do with this whole discussion. Again, since you dishies always listen to the E* spin doctors -
OLN DID NOT FORCE E* TO TOTALLY REMOVE THE CHANNEL - E* CHOOSE TO DO THIS, BECAUSE HE COULD NOT GET THE NHL FEED OF OLN FOR THE SAME PRICE AS BEFORE!
E* COULD HAVE LEFT EVERYTHING AS-IS, SANS THE NHL, BUT CHOOSE TO STORM OFF IN A HUFF!
Tony, you can do E*'s spinning forever, & it doesn't change this little fact one iota.
As to the cost issue. By dropping a channel to a lower tier and being charged the same amount per subscriber LOWERS THE MARGIN ON THE PACKAGE. You have increased costs on that package. The company needs to either absorb the cost by lowering their margin or raise the price. There is no other alternative.
Obviously you didn't read my post completely, nor must you understand how prog contracts work. If E* was to move OLN down to AT120, most likely the PER SUB charge to E* would, in fact DECREASE per sub, because in most cases, a prog provider bases the per-sub charge on a sliding scale - get more subs, your PER SUB charge goes down. It's pretty simple & I'm surprised you don't know this. YES, I DO understand it would add to the cost of AT120, but NOT as much as you guys would have everyone believe.
(And BTW - thank you for not putting your reply today over my original post, like you did last night & which I didn't appreciate - I thought that kind of stuff only happened over at the "talk" board & there's no need to do that to get your point across
