I've been rooting around on the 'net for a couple hours trying to get my own answers but I still have some questions.
I have two R10 Tivos and two standard receivers. My main tube type TV just went out and I want to upgrade to HDTV where that set is and leave the others as is for now. I've done my own installs in the past but will probably have this one done professionally since it seems to be rather difficult to get proper alignment, plus I can probably get the equipment cheaper. It seems that the best way to go is to just order from Directv.
My present dish, 3 LNB WNC, is mounted on the side of the house, but I hear that the 5 LNB dish will be too heavy for this. I have a 4" iron post from an old C-band dish still installed about 12' away from my present dish. Is this post suitable for the new dish? It's 36" tall, plumb, and is rock solid.
I have an Eagle 4x8 multiswitch and I assume that this will not work with the new setup?
Will I still have 4 cables coming from the dish and 6 leaving the new multiswitch, just as I do now? I want to move the multiswitch into the crawlspace and need to know how many cables to run out to the post.
Also, I live in zip 42104 and am not eligible for Nashville locals in spite of having only one lousy ABC affiliate and nothing else here. OTA I can get Nashville CBS decently, NBC marginally, and ABC poorly Hence, I have a Tennessee service address so I can get Nashville locals. What do I need to do in order to keep getting the Nashville locals? Should I "move" to my billing address, then move back to TN after the install? If I do this, can I do it immediately before ordering the upgrade, and then switch back immediately after the install, or should I wait a while?
Thanks for the help, Hutch
