(1) yes you are correct on the wire and the clamp, you can have a hundred clamps on a single conduit or water line.
(2) Go to radioshack and get an antenna ground lug kit for a few bucks, cut the messenger wire so that it will reach the ground lug wich you will need to bolt to the foot plates ankle region through one of the holes or through the mast elevation slot, be sure to strip the wire and put it in the ground lug.
(3) You do not ground switches, switches are not approved by the NEC for grounding purposes, the switch(s) should be placed between the ground block and the receiver(s).
