I need some help on a no signal problem, that I cant figure out. But first the background;
The FTA system in my shop is made up of left over C and KU band equipment.
The Dish is a C/Ku 10 footer with chaparral co-rotor, chaparral C and Ku LNB's. I use the Chaparral Sierra analog receiver as a Mule to drive the dish and polorotor.
The actual receiver is a old Coolsat 5000. The system works like a dream with signal quality levels of 80 Plus. The only problem is the Coolsat 5000 can not receive HD programming.
Recently I bought a new receiver for my home, thus making my Openbox S-9 surplus. Yesterday, I took the Openbox S-9 to the shop. It was going to replace the Coolsat 5000 so I could receive HD programming. Since the S-9 is not controlling a motor drive, I shut off the Motor in the menu. The LBN LO frequency on the Old Chaparral C & Ku LNB's is 10750, same as the system in my home, so the frequency is correct. I even tired other LNB LO freqs listed in the S-9 Menu...nothing. I tried the S-9 with the motor turned off and on.
I unhooked the working Coolsat 5000, which I was watching today and connected the Open Box S-9. Zippo.....no signal on any Satellite. It sits there with no signal not receiving, yet all menus and memory work fine. I took the S-9 back in the house and hooked it to my home system.....it works fine in the house. I rehooked the Coolsat in the shop.....it too works fine. Tried the S-9 one final time, no signal whatsoever.
Can anyone help with this problem. Does not make sense to me.
8Valve
8Valve
