New set up problems
srtowner
4
Alabama
Ok I'm a long time Dishnetwork subscriber. I'm upgrading my system and I like to do all the stuff myself rather than have and installer come out. I'm having a little bit of a problem with my new set up. Here goes- I live in Alabama zip 36804. I have a 1000.2 dish peaked on 119 @ 70ish signal strength on a vip222k reciever. When I do a check switch test the only Sat. that showes up is the 119 sat. I wanted to make sure everything was hooked correctly and had good signal on all three sats before calling to activate my new reciever. Now my question is Do I have to activate the reciever before the other two sattelites will show up?
Thanks in advance for any help I may get.
Even though the 119 LNB is the center one, it will be Port 1 on the receiver's Check Switch screen. If 119 isn't on Port 1, you are misaligned not only w/r to azimuth (east and west) but likely also on elevation. Foil over the outer LNBs and find 119 with the center unfoiled LNB.
I still can not get it to show anything but sat 119. And if I cover the 2 outer pick ups nothing showes. Sat 119 is being picked up my the 3rd one, closest to the extra dish input. After a check switch the other 2 show up as connected but no signal. This is the first time I've set up one of these 1000.2 but I have done a couple 500's and several 300's for friends. This one is just giving me fits.
im not real firmular with this dish, but maybe these guides will help..
  • DISH_1000.2_Installation_Guide.pdf
  • DISH 1000 Installation Guide.pdf
  • DISH_500+_and_DISH_1000+_Installation_Instructions.zip
Make sure mast is level. Leave the two outer ones covered and use the center one to get 119, sounds like you are about 9 degrees too far right, then check outer ones. If they are not in properly, it should be a slight adjustment on the skew.
61.5 sucks in the rain
HD Tuesday Roundup: Panama City, KBAK, Eau Claire, and Wausau
