I just seen over at DBS Talk that Moderator Earl Bonovich has posted that software version 10B8 has started to spool to the R15-500. Here is what he says the fixes are:
"- 30 Second SLIP
Hitting the Clockwise Advance button (forward) the unit will FF exactly 30s of recorded material. It takes 2.5s to move the 30s. You can hit the button multiple times (the onscreen display will tell you how many times you hit it). 6 times will "slip" past a standard network commercial brake. Also during the movement the progress par will only remain on the screen for a few seconds.
- XM Background and Screen Saver
The XM Channels now have an updated background and now have the DirecTV Screen Saver
- XM Trick Play Improved
Some of the previously mentioned issues with Trick Play in the XM enviornment have been improved.
- Stability Fixes; Specifically (but not limited to) Find By Keyword/Title
- To Be Announced in ToDo List; Corrected (this primarily affected Local Channel Records)"
http://www.dbstalk.com/showthread.php?t=56291
"- 30 Second SLIP
