New home multi building pre-wire questions
blentz
United States
Getting ready to pre-wire a new guesthouse along w/ a new garage and detatched fitness center.
The Guesthouse is easy, the sat dish will be located on the new guest house and the SWM 8 way switch will be in the utility closet in the guest house. there will be 3 receivers in the guest house, all running SWM.
My concerns are the distances for the new detached garage and detached fitness center. The garage is 160ft away from the SWM switch. The fitness center is 300ft away.
I was considering using the legacy switch port on the SWM switch to push sat signal over to fitness center to feed one receiver (NO DVR) instead of SWM since SWM signals get iffy over really long distances. Not too worried about the garage as i have successfully run SWM feed 150ft before to one receiver.
Thoughts?
Suggestions from the pros here?
Thanks in advance,
Bob Lentz
:welcome to Satelliteguys!
300 ft is a long way even for sd signals. You might have success using RG11, but how about installing another dish at the fitness center?
Looking for Advice on Getting Upgrade
Filtering out channels so you can watch OTA and Direct TV
