Just keep in mind that the closed caption option won't be in the 1st release. As Brian mentioned it will be added later in a near firmware update release!!
assigned to Galaxy 19 KU-band satellite.
Old dogs still stick with old tricks ... I understand that. And propose to very little learning curve, to adapt to modern times. Not demanding changes in those who want live in a past. But adding some info for other ppl who has own life and opinions.
No need to procrastinate other ppl, if you don't want to change.
Spacecraft name vs Orbital Slot reference....age old discussion. I see and understand why some are interested in the history of a given bird, it's quirks, capabilities etc, but I really only care what information is where I point, not the background of what is relaying that info. I think there are a lot of others with that view as well. It is good to know that this stb will merge the info and more importantly keep it current. Perhaps others like myself will find it easier to use the name conventions since it will be provided.
What about non-listed birds? Is 30W in the list? If not does it get wiped with an update. If you save your custom list via USB and there is an updated one, I guess you'll not get the changed info? The feature I'm going for here is incremental update....ie only update differences.
I will assume Hispasat (30W) will be in there as if I recall it is in the current models. Lemme check
edit: Sat list starts at Telstar 12 (15W) and goes to AMC8 (139W) so yeah its in there
You also have 10 "newsat" options to add some if you want. The only time I needed that was when a feed on 91W seemed to be peaked differently....it was off by a click or two. So I created a new sat for that transponder only![]()
COOL!
Sounds like all bases are covered...(all of them I can"see" and more...lol)
Being able to add custom slots is a plus. I presume the additions can be tagged with a USALS position? I was trying to figure out how to do that on the 200, but really havent spent a lot of time on it.
Regarding editing apps, shame it uses a db not native to CM. Perhaps our resident C++ gurus can whip up something that will port to/from a db format used by CM.
Still hands down the greatest effort by ANY stb provider to accommodate it's customer base!:
COOL!
Giftbox Front Panel
Back Panel
Media Player supports: AVI, DiVX, MPEG1, MPEG2, MP4, H264, AVC, MKV, JPEG
At free to air for so long I have receivers from pansats 6 coolsats2 sonicview 2 captiveworks2 viewsats3 openbox s9 1 azboxpremium plus 1 vantage 2 uniden supra and 4dtv 922.And no one of the receivers I have over the years are perfect all have good things and bed things.Now the new Geosatpro $125 and do 8psk h8psk 16apsk 32apsk and 64apsk are very good for the price are amazing.Thanks to satellite av.
