New FTA user
If you want to aim for another satellite using a vertical polarity transponder you will need to enter it into your meter (like you did when you entered the horizontal one, 12152 H 20000, for 97w). Say you wanted to find 91w. You might enter 12011 V 13333 since this is an active transponder for some news channels there. Then you would position your dish at the approximate location for 91w and use the methods we have mentioned in the thread to look for and fine tune your dish for a satellite. As Dan said set polarity in your satellite receiver to Auto. Once you find a sat using your meter you will connect your satellite receiver and do a blind scan as you did before. This will show all channels (H and V) you can get. Again what you get depends on many factors (dish size, proper aim and settings, etc). Most important is to have fun. If it gets frustrating walk away for a while and come back later with a fresh look on things. Enjoy! :)
So basically onnl auto the sat meter will find both horizontal and Vertical
Not quite, on the WS-6933 sat meter you need to specify H or V as you are entering a specific transponder to use while aiming your dish. There is no Auto setting for polarity on the meter. On your satellite receiver however you are correct. When you set it to Auto and do a blind scan it will find both H and V polarity transponders and log the channels into memory. :)
So I set the frequency to vertical then adjust the lnb
Just the set the receiver to auto it will do both. Your do south satellite if you stand behind the dish anything left of your do south are eastern anything right of your your do south is west. My do south is 85w anything to higher in numbers is west. Not trying to confuse you. Your do south is so you can setup a motorized dish.
Yeah, I think you are going to confuse him. He is talking about the pre-programmed satellites in his receiver. The East birds are not what you are talking about.
admarvelous all these satellites that we are after are in a geosynchronous orbit. They are positioned above the equator, around the earth called the Clarke Belt.
Starting at the Prime Meridian line which, is designated as 0 degrees, and heading West from there is considered West satellites. Approx. 97 degrees West of the PM Line is where 97W Galaxy 16 satellite is.
East satellites go the other way. You cannot see any of the East satellites from the continental US.
Wow, this was quite a read. That part with the drunk lady-friend was a new one. It's a good thing, but I'm not sure how she bent the dish without falling off the roof. I didn't see any pictures of the bent dish. I'd stop the whole process until the pole was relocated to a safe spot away from power, checked for plumb and the dish checked for trueness (or replaced).
Lol when she knocked it over it wasn't on the roof yet its not bent bad I was able to put it back in place
Oh ok no need to search east then. Ok what's the best way to find the azimuth with the compass do I start from the location of the dishes pole or do I set it from the lnb pole
This is already a really long thread where some very knowledgeable and capable people have given all the answers - use dishpointer.com and find your address with 97w as your satellite - and then you'll know exactly which landmark to aim it at.
Once you've relocated the mount to a safe place and make sure it is plumb - meaning level on top of the mast and made sure you have clean line-of-sight to the satellite
Then set the Elevation on the dish to 39 deg
Then set the LNB skew (twist) about 14 degrees - facing the dish you will turn the LNB in its holder - turn left a little bit
Then put the dish on the mast and aim it at the target you easily identified on Dish Pointer
Set your meter to your desired - strong - transponder and make sure your meter is set to the correct SAT, with the correct LO and slowly move the dish back and forth and looking for signal and hopefully quality will come in. Once you get the Azimuth correct - tighten and adjust elevation and also skew. Depending on the LNB, you may also adjust the LNB in closer or further out from the dish.
Done.
Thx for all the I believe I have it all figured out what I done did was lock on 97W 12152 20000 and blind scanned. I just switch the frequencies on the sat meter and blind scan to watch different channels
That is NOT a blind scan. That is a transponder scan. :)
Lol ok still learning but it works lol I done got the African news station NBC mountain west um the Arabic stations the Vietnamese stations all kinds of things and that's just one Sat I'm loving this dish but I'm bout to buy a C band dish now
Please don't start a new thread when you do so. Just keep going with this one, it's in your best interest to do so.
Thx to everyone who helped me I got a lot of good info. I just have one question before I start looking for more Sats. Are the Sats close to each other in orbit. Like when I look on Dishpointer it'll say one sats azimuth is 202 and when I look at another sat it'll say the azimuth is 209 that doesn't seem that far off
Once you hone your skills and fully grasp the concepts around mounting, pointing, and tweaking - you could easily add a motor which would give you access to all the satellites visible to your location.
Thx for the info On looking to buy a C band dish my question is does a C band dish pick up ku band as well
Yes, most Cband dishes are pretty good at Ku band but some people would say you are better to have 2 dishes -1 Cband,1 Ku. Those people are not wrong, but I made mine work very well.
I have a 10ft KTI mesh dish with a Chaparral Corotor II+ with very good quality LNBs and a satellite meter, so I have optimized my system over time.
I have gone from separate LNBFs with the Ku in the center and Cband as a sidecar, then to a C/Ku combo, and recently to a Corotor II+. I prefer my current setup over the others.
A lot of reading and learning is a good idea before you spend money. I credit the guys here and their past threads for the success with my setup.
Ok so its good to have both so if I use the C band KU combo I would need a splitter to hook both of them to the reciever box I'm assuming
Solar Outage - As a pointing tool
VBox-X craziness
