New FTA Setup at Parents' House
Just because it is has been discussed in a thread on Satelliteguys doesn't make it the defacto. :eek: One must consider the type of usage ... I have smoked a pair of jumper cables on a tractor that worked perfectly jump starting an automobile. The failure wasn't because of defective cables, only that I used them incorrectly! :D
Trip has installed a standard FTA receiver with over current protection. The event described in the thread would not happen with a current protected receiver. The biggest issue that Trip needs to be concerned with is the additional signal loss incurred.
We sell flat cables and the supplier indicates that the product is UL listed. We need to be aware of proper useage. Your linked thread makes a very important point regarding the manner that the flat cable was installed. I agree that these cables are not intended to be used in high traffic passages. Installing in a low useage area will provide greater longevity and reduced chance of failure.
Thanks for support. BTW, how were those short cables built? was there in the centre a flat strap of foil, clad with insulator, and surrounded with a mesh of outer shielding conductor? Or, was it made with two separate wires from symmetrical TV cable (used mostly in Europe)? The first design would introduce sort of parasitic capacitor to the cable, and the second - would make it vulnerable to RFI (but, probably, not very harmful). Cheers, polgyver
Have installed both types. Never noted any RF ingress or significant decrease in the Signal Quality, though I would also expect that they would be more susceptible.
