It is the smart card Dish updated me with for my receiver , which is a 2700 model. I am not receiving the 110 satellite channels on it, however the receiver in my other room which is also a 2700 model brings in the channels on 110 okay. This just started happening yesterday. Is there anything that can be done to test, or remedy the problem with the receiver that is not receiving 110 channels?You need to test 110 and 119 (if you have a Dish 500) and 129 as well (if you have a Dish 1000). 60 is pretty decent. I usually check transponder 11 on 110 and 119.
What smart card are you talking about in particular? Did you already have one when you got the receiver or did it come with one? What model number is the receiver? They require a purple G3 smart card unless its one of the latest models that do not require the card.
OK, now we know why you are thinking of a new receiver. Really anything between your switch and that receiver could be at fault. So buying a new receiver will only fix the problem if it's the receiver that has gone bad.
I would recommend swapping the 2700's and see if the problem moves with the one that can't get 110. If it stays with the cable, then you know your receiver is fine and you need to fix something upstream (cable, swtches, LNBs).
did you perform a checkswitch???
menu 6-1-1 test
