I recently switched from a very stable 622 to a 722K so I could use the Sling Adapter. After about 2.5 weeks of working well, the 722K started doing restarts on its own quite often. I called tech support and, after going to the second level and having the receiver reset a couple times during the converstation, a tech was scheduled to come to the house the next morning. The receiver was replaced but the replacement started behaving just as badly shortly after the tech left. Thinking that the problem might lie with one of the attachments to the 722K, I removed the MT2 tuner, the Sling Adapter, USB drive, and ethernet broadband connection. I took the 722K off of the UPS it was running on and connected directly to the wall AC. After lots of testing (and seemingly random restarts), I found one test that has repeatedly caused a restart:
1. Pull AC power so receiver goes through full restart
2. Wait till receiver completes restart
3. Select an HD program from the current guide
4. Press record and start recording remainder of show
5. Select a 2nd HD program from the current guide
6. Press record and start recording remainder of show
7. Double press DVR to go to My Recordings
8. Select the last show that is recording
9. Select "Stop Recording" from the menu
When I do this, the receiver will continue showing the program in the small window for a minute or so but the remote control will be unresponsive. Shortly, the receiver will do a restart.
Both receivers were running L682 in Single mode
Can this be a software issue or have I gotten two bad receivers?
