Hi, I'm a current E* subscriber, running a 6000 in one room, and a 4900 in another. I'm on the East Coast, and have a 2 dish setup, one 500 (for 119/110), and one 18" (300?) for 61.5; these have somewhat older (legacy?) LNB's. Each is connected to two SW21 switches, allowing all 3 satellites to be viewed by each receiver. I did this installation of all of this equipment myself, and if you want to date it, it was after the launch of the 6000, but prior to the availability of the 8VSB OTA module.
I have a 942 on the way, and need to upgrade. I want to place the 942 in one room, keep the 6000 in another, and dump the 4900. So, I will need to see all three birds from three satellite lines, two on the 942 and one on the 6000.
Do I need to upgrade everything to DishPro, and if so, which LNB's and switch(s) should I use for the most economical (but fully functioning for the 942) setup? I assume I will need the DishPro adapter for the 6000 as well.
Thank you for any help you can give. I understand that the 942 is tricky unless the LNB/switch setup is spot-on.
Jeff
Jeff
