Need Help
wayne231
215
Memphis, TN
Using the elevation and azmuth given on the receiver and at dishpointer.com
for 39056, all I can get a signal on is 129. I need to get 110 and 119. I'm using a dish 500 plus. I thought that 129 was lower in the sky and wouldn't be in the same plane with 119. Anyone know what Im doing wrong? (FYI: the azmuth is 119, the elevation is 44 and the skew is 123. The elevation seems a little low to me.)
Keep going toward the east, that is toward the left if you are behind the dish. Also cover the 110 sat on the lnb,with tin foil, this way you get 119 and 110 should show when foil removed. The 110 is the one on the left of the lnb,as you face the dish from front.
Dan
61.5 or need for wing dish
