I have a 622 where the 2nd tuner output is being run to my 2nd TV using COAX. I do not subscribe to local channels. I have a COAX running from an OTA antenna already available at the 2nd TV. My 2nd TV only has 1 tunerr (ATSC/QAM). How can I combine the OTA signal and the 2nd tuner into one cable?
I used a splitter (in reverse I guess?) and it seems to work OK, but I'm not able to get some of the OTA channels. I set the 2nd tuner to modulate(?) on CH 69 (antenna). But some of the OTA channels I'm not getting are not even close to 69.
Is there a better way to combine the OTA signal and the 2nd tuner output? Any specific splliter/diplexer that works well in this situation?
P.S. I do not want to use a A/B switch.
Thanks for your time!
