NE1 recieving HD locals from Louisville, KY??
blur2u
12
I currently live in Bardstown, and I was wondering if anyone is receiver OTA HD in that area....I don't want to buy an antenna if I can't get a signal!
Thanks,
Sam
Zip
My zip code(where I live) is 40004. I am not sure what the zip code is for Louisville.
The Louisville towers are about 40 miles NNW of you at 338 degrees. All are UHF except WBNA-DT which broadcasts on ch 8. Digital frequencies are ABC 11.1 on 55 back to 11 2/09;CBS 32.1 on 26; FOX 41.1 on 49;NBC 3.1 on 47; Independent 21.1 on 8.
If you are not down in a low spot, and you use a good antenna such as the CM 4228 you might have a good chance. The 4228 is not good on ch 8 but if you do not need it. Also ABC is going back to ch 11 by Feb 2009 - might be an issue, but the 4228 is better on 11 than 8.
From 2 miles north of Bardstown here is what's available. Your reception will depend on the exact location of your house. The correct antenna is a Channel Master 4228 with a preamp such as the 7777. It will have to be on the top of the roof, perhaps with a 10' mast. You will not need a rotator for the main Louisville stations, they're all within 2 degrees.
To see for sure, type your address into www.antennaweb.org .
* green - uhf WLKY-DT 32.1 CBS LOUISVILLE KY 334° 41.8 26
* green - uhf WHAS-DT 11.1 ABC LOUISVILLE KY 332° 41.6 55
* green - uhf WDRB-DT 41.1 FOX LOUISVILLE KY 332° 41.3 49
* green - uhf WAVE-DT 3.1 NBC LOUISVILLE KY 334° 41.8 47
* lt green - vhf WBNA-DT 21.1 i LOUISVILLE KY 313° 21.1 8
* red - uhf WBKI-DT 34.1 WB CAMPBELLSVILLE KY 182° 21.3 19
* red - uhf WKZT-DT 23.1 PBS ELIZABETHTOWN KY 246° 23.7 43
* blue - uhf WFTE-DT 58.1 UPN SALEM IN 332° 41.3 51
* violet - uhf WKMJ-DT 38.1 PBS LOUISVILLE KY 334° 41.8 38
* violet - uhf WKPC-DT 15.1 PBS LOUISVILLE KY 334° 41.8 17
Do you know of a list what channels change in 2009?
ralfyguy
my fingers are killing me typing this list for you.
edit/find next-enter a city or station call and search to yar hearts content.
Current DTVChannel
Current NTSCChannel
Tentative ChannelDesignation
example
wstm syracuse
54
25
  • DA-05-2649A2.txt
Rick0725 said:
ralfyguy
Current DTVChannel
Current NTSCChannel
example
wstm syracuse
54
25
Thanks for the list, and sorry about your fingers, makes me feel bad now. But this is very kind of you. I owe you one!:up :up :up :up :up :up :up :up :up
A beer solved my reception problems
OTA Antenna Frustration - Help !!!
