ocaddict said:
These receivers are simply computers running *E's version of an OS. I know w/out a doubt they are upgradable in some form or fashion physically, but curious as to why E* says they will not upgrade them to be MPEG-4 capable.
I don't know the exact internal workings but heres what I assume is the reason.
In using your analogy, it isn't the OS that is the problem. It would be more like having an ALL-IN-ONE computer motherboard with everything
soldered in place.
Now take that motherboard and assign it a top throughput speed of 100MHZ on the front side bus.(arbitrary value) because the FSB chip has a top speed set internally upon manufacture of the chip.
So, even if you upgrade the software, the hardware still remains a fixed value and mpeg2 decoder is on a 'chip' of the main board. Therefore E* recievers can't be reprogrammed to handle the new encryption/compression of mpeg4.
Ideally an EEPROM decoder would have been the best method to do what you are saying, but then it would leave E* to more expense and vulnerability of hacking the chip. (there already is enough of that going around with the hard coded chips in place) That in itself is one good reason to change the whole data stream to mpeg4.
Sending a unit back to be upgraded would be nearly impossible since the hardware logistics and manpower cost would outweigh the replacement value alone.
I'm not defending E*, but it is a technology transition that mimics reel-to-reel, to 8-track tapes, to cassette, to Compact Disc, to mp3 players(ipod). You will be able to 'fit' more information into the same amount of space and that is what todays society/market demands.
Now back to the idea that E* will give away all these receivers for free is a fantasy. IMHO there will be some 'angle' that will get the customer to PAY for these upgrades in one form or another. You will either be forced into a 1-2 year agreement, or every Jan-Mar, you will see a programming/service fee increase in your monthly billing.
Doesn't matter if it is D* or E* or cable, you(me), the customer, will be the one to absorb the cost over time. It has been, and always will be that way.
