If I put a multiswitch outside.
Can I do away with the grounding blocks and run a ground wire from the multiswitch to main electrical ground for the house?
Do I need the multiswitch powered or does that depend on the length of the cable runs?
If I need a powered multiswitch switch will it be powered by running a coax line from the power supply inside the house to the multiswitch or do I have other options?
Thanks.
Thanks.
