Hi there,
I've got a 'wide' dish with 3 LNBs. On the dish is a box (multiplexer?) that results in 4 lines that come out to potentially 4 different receivers.
I've got a DirecTivo box that uses 2 of the lines since it has 2 tuners. I have a second receiver that uses the third feed. I have one unused line left over.
I recently aquired another DirecTivo box. Since it has two tuners and I only have one line available, I'm wondering the following....
Do I need to swap out the main box that takes the 3 LNB to 4 lines for a unit that does 3x5 (or 3x whatever), OR can I simply add another box to the current configuration, kind of in daisy-chain fashion, that does like 2x4 to two of the lines to give me the extra feeds...
Hope that makes sense. So basically, can I add on these splitter boxes to each other, or do i have to swap out the main box for more ports....
Thanks!
Thanks!
