Could you pls help. Currently having 3LNBs for (13E, 19.2E, 23.5E) on fixed dish. Additionally I will have payTV from 4th position soon (1W, they use dedicated receiver with paired device and card). 4LNBs for required position on one dish are too much. I can not have 2 dishes because of space. I would like to be more flexible by installation of SG2100 because of available view. [SIZE=-1]Wavefrontier [/SIZE]is much more expensive and not flexible. Current receiver is required to keep due to better features. Therefore final requirement is 2 receivers, one dish, 4 different satellites. To reduce number of rotations, I would like to keep current 3LNBs for most frequently used satellites/positions on the dish even with motor. I see two basic issues - the first issue is how to setup current receiver to use motor and disecq switches for multifocus (if I choose programs on one of 13/19.2/23.5E positions, dish should go to "basic" position where all 3 LNBs look at appropriate satellite, while motor should rotate in other positions and middle LNB should be active only). Second issue is whether second payTV receiver will not confuse motor - maybe first "master" receiver should control the motor and second payTV receiver should be used as decryption device only without ability to control the motor. Not sure whether this is realistic and can work together. Thanks for advice.
