Moving dish a few inches?
Normally, you can't do that as the compass will be too close to the metal and cause the compass to be off on the readings, but your on the right track.
Back in the Dish days I found 110 with a magic marker even before the satellite was turned on.
Found 119, found 110, then used a marker to mark the position on the Dish.
Set the Dish in the middle of the 2 marks, and when they turned on the satellite I had like a 60% signal.
Reactions: TV Junkie
You can do that, actually. Yes, the reading will be off, however it will be off in both locations (pre / post move). Is my direction really 171? No. It was closer to 177 I think. But if I make the measurements match, 171 pre move, then 171 post move even if inaccurate, boom TV.
Can i use a h25 and HR54 on the same system?
4K Client Continually Missing Data
