I didn't even think of the cable! Yeah, i probably need more cable t move it 12 feet
You can do it,
Here is the list of items you will need to cover.
NEW LOCATION = From what you say there are no obstructions and you are just moving the dish in a straight line away from where it is now pointed (SW).
MATERIALS
NEW CABLE = RG6 is the standard coax in use. Measure the length of the run along the ground. + Measure the length from where the dish is now to the ground. + Measure the height from the ground to where you want the new dish. Add them up, probably around twenty feet from what you say. DO CHECK AND SEE HOW MANY CABLES ARE NOW RUNNING OUT THE ARM ON YOUR DISH! You need to run that many cables to the new location. IF more than two....get 1 in conduit & bends.
NEW STEEL POLE = Examine the mast (gray pipe ) you are currently using. It will either be 1.66 in diameter or 2 in diameter depending on the dish model you have. Go to a big box store and get a
10 ft steel tube fence post to match your mast.
CONDUIT = Also get a 10 ft length of 3/4 in (see cable note) gray electrical conduit and (2) two 3/4 in 90 degree bends. You don't have to run the cable underground in conduit unless you want to. Couldn't hurt. The conduit and 90s are to protect the cable as it comes out of the ground and rises to where the connections are being made. Weed eaters will ruin your day. Even lawn mowers bumping the cable will eventually ding it. Protect the exposed cable!
FITTINGS, CONNECTORS & TIES. To join the extra cable to the existing cable you will need one cable fitting & one barrel connector. To make a proper fitting installation there are several special tools available. Acquire enough fittings for both ends of the cable (s). You will need a barrel connector for each line. At each end you will use a few quick ties to form service loops and keep the cable from blowing around.
CONCRETE = Enough to keep your new steel pole from moving. One # 50 bag of gravel mix & one #50 bag of quick set concrete should do it. If your soil is sandy and or recently placed during construction you may need another bag.
THE WORK
AT THE DISH Dig a two shovel wide x three ft deep hole. Measure from the bottom of your hole to dish height + 1ft & cut your pole. Dish height must be above your local snow amount and the arm should be high enough that lawn cutterrs will not walk into it & twist the dish or break the arm off. BEFORE YOU POUND THE POLE IN hit it wits a large hammer to dent it---or drill & run a bolt through the pipe where it will be in the concrete; a muffler clamp will also work for this. You do not want the pole to spin in the concrete!.
With a wood block on the top of the pipe to protect the pipe end.......pound it into the bottom of the hole at least the 1 ft you measured & dump in the whole bag of gravel mix without water. While you are working keep the pole "plumb". This is critical to later work. Tamp the gravel mix as hard as you can while keeping the pole plumb. Prepare the conduit bend and a length of conduit to rise to the dish and away from the pole a foot. Quick tie this to the pole. Running the cable in the conduit & bend at this point makes it easier. Mix the quick dry concrete according directions and dump it in when the conduit & cable (with extra for the dish install) are done.
ALONG THE CABLE RUN you don't have to dig a trench. Open the sod with your shovel several inches down. Clear the bottom of the cut with a tool and WITH A WOOD OR PLASTIC pushing tool...like a board... push the cable into the bottom of the cut without damaging it. The cable goes through a 1 ft piece of conduit....the 90 bend...and a vertical run to the dish and cable junction at the old dish location. Attach the vertical conduit to both the building and the pole with quick ties or concrete cable clips.
AT THE CURRENT DISH LOCATION.........Remove the cable from the dish by disconnecting the cable from the LNB using a 7/16" wrench. Remove the dish from the mast by loosening the back bolts. Connect the new cable to the existing cable using the barrel connector and fittings while making a service loop where thet meet. Protect this junction from water.
AT THE NEW DISH LOCATION........cut a fitting for each cable end & connect all cable(s) to the LNB after the cable has been fed through the conduit..........prepare a cable length that runs loosely loosely from the LNB down the Dish arm around a small service loop (6-9 in diameter / two ties) & down the pole into the conduit. Quick tie all cable neatly................slide the dish on the new pole.....connect the LNB... and snug the back bolts so the dish will move for tuning.
That is about it. If you have done everything correctly when you turn on your 101 sat signal meter you should get a signal as you swing the dish through the azimuth to the signnal. Tighten the back bolts without breaking them
Questions?
Joe
