Mounting 2nd lnb for 103.0W ?
Here's your explanation:
DVB S2 8PSK FEC 5/6
S2 8PSK with a FEC of 5/6? It's lucky we can get it at all on a small dish. Those specs need much higher quality level (IE: bigger dish) to keep the signal locked properly.
Lot of good brainstorming in this thread.
Really enjoyed it. :up
But now please turn your attention to the thread marked: SES 3
The bird will be replaced, and the skew/tilt/problem, will be no more. :)
And, to sum it up, quoting from respectable sources like TRWAM or Padre Pio, we can say "AMEN" to that
Step #1: Break into shed, retrieve ladder
#2: Dig out dish
#3: Attempt to get 103w.
When facing the dish, is it 26 degrees clockwise, or counter clockwise?
Cheers, K
No avail.. turned the lnb clockwise to 25'ish degrees without success (regular channels still came in). I couldnt actually get on the roof of the shed due to ice so I moved the dish to 127w where I was able to access the LNB from atop the ladder. Doing this in the winter is a bit dangerous so am going to wait until the spring and re-install the dish at a more accessible place (4 foot pole off the ground). It might be a long winter since patience is not one of myh virtues.
Cheers, K
Set the 2nd LNBF as it were for 83w. Confirm clockwise rotation when standing in front of the dish looking at the back of the LNBFs.
SG2100 Motor Issue
Mini BUD C-band Project 99w / 91W
