And that was such a GOOD Photo, that I printed it out for reference.... Not to worry, I have made correction notes on it for when I try again next year....
Thanks, SatelliteAV
Thanks, SatelliteAV
Well, let's see, -15 plus 26, that'd look pretty out of place.Phottoman,
Did you set the skew according to the dishpointer value of minus 15 degree without adding 26 degrees? I found out that Dishpointer does NOT provide special info for this Sat's "wacky" (quoting from Iceberg) skew. What is the present skew of your dish' LNB? Cheers, polgyver
Actually,mine is done, I had Phottoette inside and I would move it a small amount, she'd tell me if the signal dropped or gained strength, and I'd move it ... repeat, repeat, repeat ... great signals, fixed dish and I am done with it, but thank you.Photo, skew that thing to -36.4 and you will be a lot closer.
This I already did, and I found out that for my location, which is close to meridian 79, satellite 97 W should have skew 17.7 , satellite 101 skew 21.2, satellite 103 skew 22.9, satellite 82 skew 3.0. Therefore I concluded that Dishpointer did not take care of special "twist" of sat 103 (otherwise it should suggest skew close of that of sat 82, namely around 3 degrees). As other members suggest, extra twist of LNB is surely needed.Well, let's see, -15 plus 26, that'd look pretty out of place.
If you would go to dishpointer and enter your address, or at least your town, then scroll down to the satellite you are looking for, then look under the list of satellites, you'll see nearly everything you need to point that dish the first time.
Photto
Never tried it, but if the diameter of the housing is the same, it should work fine. If it is a little different you should still be close enough, since you still want to tweak it by looking at a signal meter, either stand alone or receiver and tv out at the dish.
That is what I though, I already transfered the skew readings from the Invacom SNH-031 to the other two LNBF, as soon as I get my getto bracket bulit, will give it a try.
I still do have a few skew clarification question, according to dishpointer for my location I need to skew the LNBF to 21.4 degrees clockwise (looking from the back) of the dish... Is the second LNBF going to be 21.4 degrees clockwise from zero (dishpointer said that this reading are for a stationary dish) In a word "no". You need to look to see what Dishpointer says for 83W and use that. Dishpointer does NOT factor in the odd skew on the Ku side of the bird
does this skew reffers to having the extra LNBF to the left or right of the original LNBF?
Does not matter which side
.... Also about how close are the two LNBF going to be to each other when the extra LNBF is mounted?.
You may be able to go as close as 4 degrees apart, I have mine 6 degees apart....If my Dish and primary LNBF is looking at 97W the secondary one is looking at 103W
Thank You.
Yesterday I went out and re-aimed a .75M dish that had been pointing at 83W after I read about CozyTV. Chanel Master dish has been pointed there so long that I don't know why I hadn't thought of doing it sooner. Anyway, I went to dishpointer.com and saw they recommended a -15.4 degree counter clockwise turn as seen standing BEHIND the dish I think I took MAYBE ten minutes to get it pointed in the correct direction, then I used the two way radio between the house and myself, checking on signal strength. The biggest problem I had was that the LNB was too deep all along, but that too is now corrected.
The final result was super, there are several programs on NBC that I like, and now add CozyTV to that while I wait to see if our repeater channel from Phoenix offers CozyTV as a sub channel.
I'm NOT going to hold my breath waiting for THAT to happen.
Photto
PS: Merry Christmas Every one, from Our House to Your's.
I find that skew need not be exact, i.e., there is room for error in each direction without sacrificing much quality. I usually just eyeball it, then maybe a fine tune to get those extra one or two quality percentages.
