GEOSATpro microHD 1_31 firmware not logging channels in properly all the time
stargaze
916
56
Out there somewhere
Noticed using the latest firmware 1_31_2013 that some channels on SES-1 would scan in proper freq/SR and fec but the pids were different and channels would not play.
this occurred on 3710 V
manual entry of 3710 pids plays fine even when leaving that channel and going back but...
not so on 3773 V
The 3773 V channel shows up as pids V 49/A 52 /P 49
but should be V 257 /A 258 /P257 and when you manually enter it in it plays but once you leave and go back to that channel it reverts back to the 49/ 52 pids which are not correct.
Tested on 4 test bench units with no problems. Transponders 3709 and 3773(2) both scanned the correct PIDs on 5 successive scans. No "PID Shifting" happens.
  • Perform a Factory Reset then remove the power for 10 seconds after updating the firmware?
  • Install a pre-built User Database (.udf) file or build a new channel list from the satellite list provided with 1_31 firmware?
