You use your current software to do the file dump to usb. After loading the NEW software, then you restore the user database through the Upgrade function.
If someone has a hard drive set up can you run a test for me and see what results you get
Ever since I got the Manhattan I have tried to record the Montana football games (since it records HD fine normally and the azbox doesnt). When I try to play them back after a specific time (may be 10 seconds in, may be 2 minutes) the picture skips...as example I recorded a 5 minute segment and when I play it back at 1:45 it skips...it goes back to 1:43 and continually plays 1:43-1:45 then goes back. This is the only feed I've seen it on (all 3 or 4 weeks now). Sometimes it does it within 10 seconds of the beginning of the feed. If I FF past it a little bit later it will do it again.
Can someone verify it does it to them too?
Hi All--
New to forum. Have a new RS 1933 and am positioning dish with my DSR 922. Several questions:
-- does the firmware need to be decompressed before loading to the 1933; my computer does not seem to think that the file needs decompressing
-- will version 3.4 wipe out all of my scan data as earlier versions are said to do
-- C band is working pretty well but so far cannot get any Ku band. Does the 922 put lnb power out on both C and Ku ports at the same time? If not, is there a way to get the 922 to switch power to the Ku port without moving the dish to a bird that the 922 knows is Ku?
Paul
And I learned about it from SatTalk radio show when it was mentioned that 3.4 was out. I came here first and didn't see it but found it on the Manhattan site.First word of it was Post #86, http://www.satelliteguys.us/free-ai...anhattan-update-3-3-thread-9.html#post2667063 .
Connect a 22 KHz switch to two lnbs. Scan a few satellites that use 22KHZ off. Then scan a few satellites that use 22KHz on. Try to watch some tv channels and change between satellites that use 22KHz and some that use 22KHz off. The Manhattan loses tv signal when you change form a satellite that uses 22KHz ON to one that uses 22KHz OFF. The dish moves to the correct orbit location but you lose signal. You can get the signal back by going into the antenna setup and then exiting back out. It acts like something is sticking. This problem is easy to see. GregH
This was my first big feeds weekend on 3.4 and I found something interesting. After most blind scans looking for feeds, I'd tune one of the found channels and there was a black screen (and it was there for minutes, not just moments). Figuring somthing was flakey and it wasn't the feed, I turned off and back on the manhattan and the video popped right in. I did a blind scan later on a satellite with known 24/7 feeds and was able to see this black screen upon tuning a signal after blind scan on a service I know never has black screens. I turned off and on the manhattan and it worked fine after that.
The report came from a very reliable observer on the East Coast, who found a feed on AMC-3 C-band.
There are no fulltime feeds that I know of in this format, but I put a great deal of trust in this person's abilities and if he says that it was 16APSK, it probably was without a doubt.
stone--
Thanks for your reply. I have a couple more questions:
-- In the tools menu, the USB functions are greyed out. Do I need to have a USB flash drive in the port for them to show?
-- Also, I do not see a 'dump to USB' function listed. Does that mean I have an older firmware? Is there any way to find the firmware version?
-- Re my setup: I previously had a Pansat 2800 fta using splitters and a DiSEqC switch. (how do you pronounce that, anyway?) I now have just replaced the 2800 with the 1933, connecting the splitter output to the 1933 SAT IN port. I don't think I ever did get any Ku on the 2800 either. I did get Ku on the 922 though when there was some to get. I am using the 922 for dish positioning and am viewing the few clear channels just to confirm my dish position.
-- Another thing: I have turned off the lnb power in the 1933 and several channels went blank but not all. Peculiar. Any thoughts?
Thank you for your time and counsel--
Paul
