Luken Changing
Still can't any green bars on this Sat for 3920 V 30000. I seem to get just about everything else around 60-72 green bars a lot of spanish programs.
I am in North Central Indiana
I am using a 10ft Unimesh dish. Also using MicroHD unit.
Have a lot of rain at present time here. I have moved the dish left and right of that transponder and nothing.
Will try later today.
Try creating a NEW menu item for this satellite, just slightly rename it (so you'll have two c-band satellites for 113w). Then do a blindscan on that "new" one, and see if this transponder then comes in. If not, then also manually enter that transponder, and do a search just on that.
p.s. By the way, if that works, do NOT delete the original 113w satellite menu item before you delete each individual channel on it first. If you delete the sat without doing that first with the MicroHD, you'll boot-loop it.
Here in northern WEST NY,or New Amsterdam (don't care as long as that city isn't part of it), 91sig-80qual using V7 on 12' Paraclypse.Wouldn't blindscan,had to manual enter xponder.
Eutelsat 113 West A 113.0W TBS 6903 DVBS/S2 Tuner 0 3919.78 Vertical 29994.969 8PSK 3/4 DVB-S2 OFF 0.20 Normal
CCM 66.857 35.993 10.2 -24 MIS: 0, BER: 0.0000000, Time to lock: 741 ms 2018-12-27 19:07:12 Z
From my PC tuner with 10' dish C2WPLL LNBF. 10.2dB s/n so not a great signal. Lots of snow on the dish though haven't had a chance to clean it off yet. About 4" of it came down overnight. Temp about 5 deg F. Channels play fine though.
Okay, switched out my MicroHD boxes and same results. I checked Lyngsat to to check if I was on right satellite. I get the Hidalgo Transponder with a very strong picture an signal. Anybody get this same channel? I must be on the right Sat. I tried adding a new Sat 113 and new transponder 3920 v 30000. No luck on both boxes.I can not lock any signal on Luken. Still scratching my head at this point.
Hidalgo is on the horizontal polarity, Luken is vertical
Can you get Ocho TV on 3880 V 30000 ? Or Green Tv on 3773 V 2530. Make sure channels you are getting are from both polarities...
Hi All,
This time of year with the leaves gone, I get 113. I get about 6 channels with Hildago being the strongest at 70% signal quality. The other 5 average between 32-45% and are viewable. No Luken mux though :(
Reactions: primestar31
Hi All,
This time of year with the leaves gone, I get 113. I get about 6 channels with Hildago being the strongest at 70%. The other 5 average between 32-45% and are viewable. No Luken mux though :(
See my post directly above yours. Please check those same ones. Luken is Vertical, Hildago is Horizontal.
primestar31,
Will check those.
My dish is not perfectly parabolic so that may account for the lack of signal with Luken
John
I am not able to get either channel you said. Just a couple I'll mention on the vertical side: Hidalgo 3819V3254, S-90,Q71 Azteca 3900V31350, S-90, Q70. Tried the new sat idea again, no luck.The V-Sde looks great on what I can receive. The H-Sde looks just as good. Tried imputing new transponders and no luck. Not even a blimp on 3920V30000 of Q.I am going to stop tonight and think about this. Thanks for your ideas!
I'll take "Name that satellite" for $500 please! HELP!
Asking for Advice for class project
