hi folks,
I currently have two Tivo Series 3 DVR's with cablecards. I have become completely fed up with SDV, and the blasted Cisco tuning adaptors that lockup, reset, and power off consistently.
I have been researching the two carriers and it seems that Dish has an interface that is closer to Tivo's, and I like their external storage setup.
I have a couple of questions if someone would not mind helping me out.
1. is it possible to control two Dish receivers in the same room(both attached to an AV preamp, going to the same TV). Tivo remotes have a 1/2 switch to allow me to set two Tivo DVRs to diferent freqs. to control both from the same remote witout interfering with each other. How can I do that with Dish?
2. Rain fade. I have read accounts that are a couple of years old that rain and thick clouds cause pixelation and outages just as I experienced a decade or so ago with Direct TV. Is that still the case, with a clear view to the sky?
3. External storage option. I am curious about the manual work required to move programs off the DVR to free up storage. Is there a way to batch move programs over, or programatically instruct programs to copy to the external storage, by retention date, for instance?
4. Also, does playback directly from an external drive work well? I am curious since the connection is only USB 2.0, if the transfer rate is quick enough for smooth playback with HD programs?
5. finally, I assume for HD DVR use I would be getting the DVR612. I have checked everywhere and can't find the back panel layout. I assume they use an HDMI 1.3 connection?
thanks very much for the help with making this decision!
Jeff
Jeff
