Been there, done that, "Closed Caption Off" is grayed out, not accessible.Press the audio button on the remote (green button I beleive) and a menu will pop up. The CC option is there on the CS5k
If the channel has Closed Captions then almost every FTA can let pass through line 21 of the MPEG stream (that is where CC1 lies), BUT your TV needs to be CC compliant, if its just a monitor then most likely wont display the captions.
Line 21 went away with NTSC. DVB uses TS streaming data.
