First an aside : when lining up an E* on 119 & 110 IF, the elevation is TOO high , then ONLY 110 will come on line. Which also means the antenna needs to be lowered and moved over to the right. Then 119 will be found and 110 will shadow in.
So, with Glorystar : AMC4 is working but G25 only show the channel where G19 has been moved.
Customer called and over the weekend G25 simply drop off .
Suspecting elevation is off.
Thoughts anyone ?
tks;
John
Thoughts anyone ?
tks;
John
